Digital I/O
NI-DAQmx Binaries Terminating with SIGABRT
NI-DAQmx installed on a SUSE 10.2 with the aid of this thread
But all binaries are failing with SIGABRT, what am I missing? Thanks!
(3,189 Views)
I'm not sure which thread you're referencing, the link doesn't seem to have posted. While SUSE 10.2 may work, it isn't fully tested and supported by DAQmx. You may have already read this, but here is a good reference on what is supported and what needs to be installed - What Linux distributions do National Instruments' drivers and software support?
There are several threads on Linux and DAQmx - here is one of the more detailed that has some good information.
Other than that, hopefully someone else out there has run across something...
Andrew S
(3,165 Views)
