Digital I/O
NI-DAQmx installation issue / nidevmon.exe application error
I just installed NI-DAQmx V8.8 on an XP machine.
I reboot the machine at the end of the install.
When the machine reboots an error occurs.  Windows prompts to select the various safe mode / last know good configuration options.
Selecting any option other than last know good configuration causes the PC to reboot and return to the same screen.
If I select last know good option then the PC boots and I can log in.
However I get an nidevmon.exe application error.
The PC is running Sophos antivirus and firewall.  I have disabled both.
I have noticed that none of the NI services are being installed i.e. are not listed in the windows service manager.
I have tried uninstalling and reinstalling NIDAQmx, but that does not seem to have any effect.
(4,119 Views)
Do you have XP 64bit, because NI-DAQmx is not supported on Windows XP 64 bit. If you are using XP-32 bit, we cna upgrade to DAQmx 8.9 which you can download here.
nAyer
(4,108 Views)
