Digital I/O
NI PCI 6225 digital imput used to read serial signal
I'm using a PCI 6225 in a project to read a binary data sent in a serial format.
The signal I'm trying to read is an output of a board that sends its ID number, for example, it sends its ID like 3542 in a binary format (110111010110) this data is sent from an single output signal of a specific board. This signal is sent continuously at a maximum of 4 data bits per second (2 hertz).
I was trying to read this signal from one of the digital inputs of the 6225, I used the Read Dig Chan-Change Detection.vi from the examples but it's not working 😞
Any idea to help me read this serial signal??
Marisol MS
Marisol Mejías Segura
Electronics Engineering
(3,902 Views)
Hey Marisol,
Change dection probably isn't your best bet because it will only latch in data on edges, so  110111010110 would be latched in as 10101010 - all repeats would be lost. Does your board send a clock signal? If so you could use it as an external clock and do a correlated digital read. I would start with the "Cont Read Dig Chan-Ext Clk.vi" shipping example. If you don't have a clock signal, you could use a counter to generate a clock and read the data.The "Correlated Dig Read With Counter.vi" example would be good for that.
Hope this helps,
Andrew S
(3,896 Views)
I cannot find the file Correlated Dig Read With Counter.vi in the examples folder....
Could you send it to me?
(3,850 Views)
We added the example in 8.7 or 8.8, ao you could just update DAQmx. Otherwise I've attached it saved as a LabVIEW 8.0 file below.
thanks,
Andrew S
(3,844 Views)
