Digital I/O
NI PXI 6552 Dinamic generation with external sample clock does not work
I am using the NI PXI 6552 to generate a digital signal, as clock I want to use an external source that I drive in the board via de CLK IN SMB connector. Always I got the same error (cod: 1074115898) from the “Write” VI block, the reason is that there is not clock signal or is not detected.
I tried the example “Dynamic Generation with External Sample CLK” and I have the same error.
The clock signal is in 3,3V logic. The same clock signal works to acquire via the STROBE pin. I have scoped the CLK and the shape is quite ok. I have tried the two possible impedances for the CLK input also.
I found one respond (http://digital.ni.com/public.nsf/allkb/884C5A76BA1A474E8625717A0068AA09) about strange behavior of CLK IN but the proposed solution does not help in my situation.
Does somebody have an idea about the problem?
Abe
(3,401 Views)
Abe,
At what frequency are you trying to run and are you certain the clock you are providing to the CLKIN SMB terminal is at the same rate you are telling software?  Software makes some calculations behind the scene based on the value you give it that may result in clocking errors if the actual rate does not match this.  Also, can you try running at a frequency slower and faster than 25MHz to see if you get the same or different errors?  Have you verified that the input to CLKINSMB meets all of the specifications outlined in the documentation?  Since this terminal is AC coupled, the dutycycle specifications are of particular importance.
External Sample
clock
requirements
Square Waves —
Voltage range 0.65 Vpp to 5.0 Vpp —
Frequency
range
NI 6552: 20 kHz to 100 MHz —
NI 6551: 20 kHz to 50 MHz —
Duty cycle
range
f < 50 MHz: 25% to 75%
f ≥ 50 MHz: 40% to 60%
Sine Waves —
Voltage
range
0.65 Vpp
to 5.0 Vpp
1.0 Vpp
to 5.0 Vpp
2.0 Vpp
to 5.0 Vpp
Frequency
range
NI 6552:
5.5 MHz
to
100 MHz
NI 6552:
3.5 MHz to
100 MHz
NI 6552:
1.8 MHz to
100 MHz
NI 6551:
5.5 MHz
to 50 MHz
NI 6551:
3.5 MHz
to 50 MHz
NI 6551:
1.8 MHz
to 50 MHz
-Ryan M
(3,378 Views)
