Digital I/O
NI USB-6501 outputs signal when plugging in
I received a new USB-6501. After installing software and hardware, I noticed it gave a "on" output signal (and turn on my down stream instrument) when plugging/unplugging USB cable and turning on computer. It is connected to a Dell OptiPlex3040 with Win7 64 bit. It works fine otherwise. Does anyone have similar experience or have a solution?
(2,850 Views)
tinglee,
The USB-6501 does not have a default high or low state when turned on, but instead defaults to a high impedance input.
You can read more about the issue in this forum post, which also describes a potential workaround.
Hannah
Applications Engineering
www.ni.com/support
(2,818 Views)
