Digital I/O
NI USB-6509 Self-Test
Hello all,
Does anyone know what the built-in self-test of the NI USB-6509 hardware or any similar digitial I/O hardware does? Does it just confirm the hardware can communicate, or it actually tries to write and read certain digitial I/O lines?
I just want to have some idea about what it means when the self-test passes or fails.
Wenhao
(5,941 Views)
The self-test is just a diagnostic that checks that the onboard chips are powered properly.  The Test Panels actually check I/O.
(5,920 Views)
Is the NI USB-6509 supported by DAQExpress?
We want to be able to configure and test all Digital I/Os using an NI application.
(3,500 Views)
is it possible to test all digital i/os using NI
(3,477 Views)
"NI" is a company, not an instrument, diagnostic tool, or software. Please clarify your question.
(3,471 Views)
You can use NI MAX (measurement and automation explorer) which is a National Instruments software to test digital I/Os using test panels
(3,458 Views)
