Digital I/O
NI USB-8451 - SPI - speed of communication
I'm using NI USB-8451 to communicate with a microprocessor by SPI Bus.
I can not reach the speed of communication 4Mb/s (NI USB-8451 module advertises speeds up to 12Mb/s).
The image below is taken from equipment datasheet.
My problem is with t3 (SCLK setup time). This module achieves 12Mb/s when the clock is 12Mhz and t3=0us, so to achieve 4Mb/s I need a clock of 4Mhz ant t3=0us.I can’t configure t3 to be 0us, is this possible?
Is any way to configure the t3 to be 0us, for the communication to be continued (without SCLK setup time)?
Thanks.
(4,928 Views)
Hi, I have meet the same issue, is there anyone who can help to explain?
(4,678 Views)
I am looking forward to seeing the solution as well!
Best regards
HKH
HKH
(4,277 Views)
I have the same problem, have you got any idea how to solve this?
(4,127 Views)
