Digital I/O
NI pci6537 malfunctioning
Dear NI,
I have problem with on of my NI cards, recently purchased.
it is:
NI PCIe-6537 Digital I/O (50 MHz, 5.0/3.3/2.5 V, PCI Express)
Part Number: 779673-01 | Serial: HB3032172 |
Registered
CCA, SHELTIE, PCIE-6537
Part Number: 192203D-03L | Serial: 1677926 |
The card is an important IO interface used in our product. Earlier it was working fine, but now our customer noticed us about the problem.
The symptoms are:
A
My application does not start, it stalls for a while then detects the card but can not set it up. It receives error -89130.
It also displays message suggesting reseting the card.
B
I tried also with NI MAX:
It searches for about 30 sec for the card.
It finds the card.
I can not reset the card and the self test fails: Error dropped: -88705
Restarting the host PC does not helps.
Host PC is a DELL Vostro 430 (i7, 8gb)
Please reply asap what to do as our customer is currently hindered using our product.
Gergely Katona
Femtonics Ltd.
(4,857 Views)
Hello, Gergely
For your first problem, please try the steps in the following documents:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000PARISA4&l=en-GB
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P8k8SAC&l=en-GB
For your second problem, try the possible solutions in the following document:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P6iKSAS&l=en-GB
Please note: when restarting your system, ensure you follow the proper shutdown sequence (power off the laptop, then the chassis).
Please let me know if any of the proposed solutions help :).
Dom
(229 Views)
