Digital I/O
NI9403 input/output setting
Hello everybody,
I'm total beginner in measuring and using NI software, so I'm sorry for possible stupidity of my question 🙂 I'd like to connect optoelectronic incremental displacement transducer to NI9403 module as a counter. But when I'm creating a new task in Measurement & Automation Software, I can't find my module in supported physical channels (New Task -> Acquire Signals -> Counter input -> Position -> Linear -> Supported physical channels). I think I have to set up input channel but I don't know where.
Thank you
Kind regards
Loobosh
(4,025 Views)
Dear Loobosh,
NI-9403 has only digital I/O, so you can't use it for tasks requiring counters.
I don't really see an easy way to implement what you want. If you are using the module in a CompactRIO chassis, you would be able to design your own custom counter and perform those measurements on FPGA.
I also found an example that shows how you can use digital input to perform encoder measurements, but it also requires a counter for synchronization:
http://zone.ni.com/devzone/cda/epd/p/id/5753
(3,996 Views)
Hi Mateusz,
thanx for your advice. I think I should try to design my own counter in LabView 🙂
Regards
Loobosh
(3,989 Views)
