Digital I/O
NIDAQ w/Borland c++ 4.5.1 migrating to Windows 98
I've got a problem when I was trying to convert a really old system (486DX) that uses PC-DIO-24 card to a new system(P4). An application was originally developed using Borland C++ 4.5.1 with NIDAQ (I think it's v4.6). I can't get the applicatio to work correctly on the new system.
On a new computer (P4 with 3 ISA slots, one of the ISA is for PC-DIO-24) I installed windows 98. Then I installed the PC-DIO-24 card and installed NIDAQ version 7.0 (Tech support told me to use this version). Then I migrated (basically Copy and paste EXE and all library files) the application from the old computer (which was running WIN3.1) to the new computer.
Now the program returns error code -99 when it attempts to configure a port (DIG_PRT_CONFIG???). I don't know where this is comming from. The card appears to be configured correctly in the NIDAQ configuration panel. No IRQ or other conflicts.
ANyhelp would begreatly appreciated.
(3,170 Views)
When the versions of DAQ drivers are significantly different, functions can often change slightly which can affect code execution. The first thing that I recommend doing is looking through the code itself and checking all of the functions, particularly the ones that generate errors. A good resource to compare these functions is the Traditional NI-DAQ (Legacy) C Function Reference Help. This is located in Start >> All Programs >> National Instruments >> NI-DAQ. I also found a couple of knowledgebases that concern the error -99. These appear to be for older versions of DAQ, but they are worth looking at.
Error -99 is returned when calling any DAQ function in Borland C version 4.5 for DOS.
What is NI-DAQ Error -99?
I hope this helps.
Hal L.
(3,149 Views)
