Digital I/O
NIDigital Pattern Instrument Driver PPMU Channel Issue
Has anyone encountered an issue with the NIDigital Pattern Drivers before with regards to their channel inputs?
Channel inputs should expect channel strings like "siteN/pinName", but what is working are "0, 1, 2..etc"
I'm using LabVIEW 2020 and TestStand 2020.
(1,091 Views)
Did you initialize the instrument properly with the PinMap?
Santhosh
Soliton Technologies
(1,070 Views)
Thanks for this. It's okay now. I was only calling the Digital Initialize on the Process Setup on the TestStand but not loading the pinmap. I thought initializing them would be enough.
Many thanks.
(1,042 Views)
