Digital I/O
NIMAX simulating a device for Non NI application
I am currently developing a .Net application for my company that required the use of USB6525 Dig I/O.
I am awaiting delivery of NEw USB6525s from NI so thought I could simulate them in NIMAX for the .Net App to be able to use whilst being set up.
This does not seem to be possible as I am unable to toggle inputs or display outputs through NIMAX for the .Net App to be able to see.
As soon as I run a task or start the "test Panels" of a simulated device the .Net App is locked out of the device by NIMAX.
Any ideas how to allow the .Net App to access the simulated device and allow I/O simulation via NIMAX ?
( NIDAQMX 19.6 & associated NIMAX)
(2,072 Views)
Hi @PeterGillham
Have you seen this link below?
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019Nw0SAE&l=en-GB
It seems you are running into a limitation as the device is reserved when running test panels.
Kind Regards,
Danielle
Technical Support Engineer
Platforms & Systems
(2,004 Views)
