Digital I/O
NPN leak sensor to DIO
I have a Netmotion liquid leak optical sensor which uses a NPN transistor. I would like to connect it to the DI of a USB-6009 for labview to sense a liquid spill. Here is a link to the product page, I have model HPQ-D11-L05:
http://www.netmotion.com/htm_files/fh_leak.htm#one
It says that the output has a load current of 50 mA max, does this mean i just need to put a resistor in the circuit to convert to a 0 - 5 V signal or is there something else I need to do in order to detect an change in output.
(4,673 Views)
You can use a resistor (1k) but you have to connect the resistor to the +5V of the  USB-6009. Do not connect it to the power supply for your device (>12V).
Kees
(4,652 Views)
Thanks, could you be a little more specific on how my wiring needs to be done. Do I connect the resistor between the black wire and +5V then measure the voltage accross the resistor for the TTL signal?
(4,636 Views)
You can connect it like this. The input is inverted. So an inactive output will show a '1'.
(4,630 Views)
Tried and worked. Thanks so much for your help!
(4,623 Views)
Glad to help.
Kees
(4,620 Views)
