Digital I/O
Need a camera for following specification
Sir, My application goes of this sort.The items arrive on a conveyor belt at speed upto 1.5 items per second. Conveyor Belt Dimension: Width 1.5 ft, length:5 feet The requirement of Camera are 1. Atleast 2Mega pixel camera 2. Capture at highspeed (objects moving at speeds upto 33 metres/minute) 3. Fast interface for Capture (USB/Camera link/GigE) 4. Camera SDK and driver availability for Labview 5. Interface and Cable to trigger Camera Image capture Sensor: 1. Which sensor will be appropriate 2. What is the mechanism to trigger the Camera directly or through Labview 3. Should be able to operate at high speeds
(3,344 Views)
siva,
For a completely specced out system, I might reccomend getting in touch with your local contact. You can find out who that is here: http://www.ni.com/domestic_sales/
I believe that someone in our department has also been contacted by you via email, but I'm not sure what the result of that was.
Chris Van Horn
(3,327 Views)
