Digital I/O
Need help installing PC DIO 96 in new computer
Hello:
I am currently running a PC DIO-96 on a 100 MHz pentium (Windows 95) and LabWindows CVI. The board controls high voltage power supplies and timing equipment for a mass spectrometer. The computer is on its last leg, and I need a new computer for this instrument. However, I did not develop the code that controls this instrument, and I would ideally like to plug this board into a new computer system, copy over the .c, .h, etc. files, and continue using this code.
The questions I have are... is LabWindows CVI compatible with the OS I would get with a new computer, e.g. Windows 2k or XP? Also, is this board compatible with those systems? Are there specific system requirements I need to purchase to utilize the
board, or can I expect to just plug it in to any new computer? If I can't use board, is there a newer one I should purchase that I can use with the existing code that has been written for the instrument?
Forgive the newbie questions, but this will be my first foray into the realm of computer hardware.
(3,216 Views)
Justin;
You will need to check the version of the CVI you are using and choose a version of the DAQ board driver NI-DAQ to compatible with both that version of CVI and the OS you choose to use.
Please be more specific about the versions you are using now so I can give you a better help.
Hope this helps.
Filipe
(3,216 Views)
