Digital I/O
Newbie: testing C-code to physical voltage output on NI-USB6501
I'm looking for a way to test my C-code to the behavior of the NI-USB6501 board without having to attach any peripherals to the board.
Brief description of my project: i create a task, one DO channel and write 0 or 1 to the lines. I want to see if my code matches the correct behavior.
Is there a tool available that shows the state of the lines (0 or 1) ?
Thanks in advance,
Sander
(3,248 Views)
There is no tool available which can show the states of the lines. You could use a boolean display in your GUI to test this.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,240 Views)
