Digital I/O
OEM version of ni usb-6501
OEM version of ni usb-6501 contains IDC connector, i want to know what is the pitch of the pins in this connector in order to build a daughter board for it??
(6,072 Views)
Accepted by mhawary85
I'm guessing it uses the IDC standard 2.54mm (0.100") pitch.
-AK2DM
(6,067 Views)
It's a standard 0.1"-pitch 34-pin ribbon connector... description/dimensional drawings in the product information PDF.
Connector for the 6501 juts off to the side; unlike the 600x-series you can't just solder a header connector on the mobo and press the DAQ/DIO onto it.
Use something like this on the PCB, pick up a few of these connectors and a couple feet of ribbon cable to make your own connecting cables.  The hole pattern for the DIO is in the product manuals as well.
(6,062 Views)
THANK YOU GUYS FOR ALL YOUR HELP
I REALLY APPRECIATE IT
(6,050 Views)
I would to know if you suceeded to build your daugther board with this pitch ? Have you got any problem ?
Thank you !
(4,063 Views)
