I see it just fine but just for grins, here it is again.
Is this a digital output? What do you see with the mfc disconnected? What sort of load are you trying to drive and does the daq device source enough current?
It is an analog output. When I test this output in Instacal it works properly, its only current source I guess is through USB...The MFC reading is fine through this 1208-FS, but analog output is not.
