Digital I/O
Open collector inputs
The ATE system I want to build with a CompactDAQ platform includes open collector inputs. Is the NI-9361 the only module with internal switchable pull-up resistors?
(1,233 Views)
So, to rephrase, you're looking for Digital Inputs with internal pull-up to allow reading signals from open-collector outputs.
Why is the internal pull-up so important?, you can externally add those pull-ups and then you have much larger selection of C-series input modules.
Santhosh
Soliton Technologies
(1,222 Views)
Yes, that is true. Internal pull-ups are are not essential. I was just trying to determine if there were internal pull-up options available other than the 9361 module. Thanks for your reply.
(1,215 Views)
Looks like NI-9422 also supports open-collector signals.
Santhosh
(1,192 Views)
