Digital I/O
OpenView( HP Inc, ) can managed NI?
English.
My office is using NI Devices...
We use OpenView for Network management, So, We want to management Ne Device in Openview process...
We using NI PXI-1045 and 1000B
Please Let me know,
1. OpenView can managing NI Devices?
2. NI Devices support SNMP protocol?
2. If it is possible, how?
Korean.
저희 회사에서는 NI 장비를 사용하고 있습니다.
네트워크 관리를 위해 Openview를 사용하고 있는데, 제가 알기로 NI장비는 snmp를 지원하는것으로 알고있습니다.
그렇다면 Openview에서 어느정도까지 통제 및 상태관리를 할수있는지 알고싶습니다.
저희 회사에서는 NI PXI-1045, 1000B의 2종류의 NI장비를 사용하고 있습니다.
(8,984 Views)
I'm not really very familiar with OpenView, but if you give a little bit more information on what you are trying to do I should be able to help you out. What is your application about? the more information you give me, the better I should be able to help you out.
LA
(8,972 Views)
OPENVIEW is a network management software from HP, I also would like to know if vi can work with OPENVIEW
(8,836 Views)
Hi Noa,
We can try to help you out, but we will probably need a bit more information.  The PXI-1045 is simply a chassis, so there isn't much to control.  What you probably would want to control is the devices that are in the PXI-1045.  What cards do you have in this chassis?  When you ask whether OpenView can manage our devices, do you mean control the acquisition or output that these boards perform?  If you can provide more details about what other NI hardware and software you are using, and what you are trying to do with it, we may be able to give some suggestions.  Thanks!
Thaison V
(8,818 Views)
