Digital I/O
Operator interface switch to control SSR NI9485
I am struggling to control a SSR module from Signal Express.
The setup is a cDAQ9188 chassis and NI9485 8ch SSR module switching a 10v supply.
I have a DAQmx Gen - Digital line output set to control the NI9485 and if I toggle the value to write in the configuration tab between high and low the SSR does function.
What I cant seem to get to work is controlling the output from a toggle switch in the Operator interface, I have been into the switch bound parameters and selected the module and port.
This is my first time with NI software/hardware so I am guessing I am missing something obvious, if anyone can point me in the right direction it would be much appreciated.
(4,857 Views)
Since the hardware is working, you should post to the SignalExpress board - http://forums.ni.com/t5/SignalExpress/bd-p/380
(4,837 Views)
Can I move the post or should I repost?
(4,834 Views)
You can click on Options and request the moderator to move it.
(4,812 Views)
(4,809 Views)
