Digital I/O
Output from Matlab not received by NI DAQ 6221
I am a student at Aalborg University in Denmark and I am working with a USB 6221 DAQ. My goal is sending a digital square pulse output from Matlab. The problem is that due to the high frequency (1MHz) I need to generate pulses with a width of 200 microseconds in Matlab and send them via DAQ to device 1. I  furthermore have an input signal from device 2 with a sample rate of 1,000 Hz. My problem is that I can't send the square pulses to device 1. I think it is probably because I try to use two frequencies 1MHz (output) and 1,000 Hz (input) simultaneously.
Can anyone help me?
Thank you in advance
Message 1 of 1
(2,058 Views)
