Digital I/O
PC-DIO-24 on Windows 2000 to PCI-6503 on Windows 7
I have an old Pentium PC running Windows 2000 that I have been using as part of a test setup with an Audio Precision System One. I am using a PC-DIO-24 to control external relays for automated testing. I am sending commands from AP Basic, which is essentially VB, scripts to the PC-DIO-24.  I need to upgrade the PC, I will most likely be using Windows 7, 64-bit, and I have purchased a PCI-6503. I am looking for assistance on how to proceed. I have tried to download NI-DAQmx, 64-bit, as a start. The web page indicates that it is compatible with Windows 7. However, when I run the install I get a message that it requires at least Windows 10.
Any ideas out there?
Message 1 of 1
(1,240 Views)
