Digital I/O
PC-DIO-96 DAQ ERROR 55135
I am trying to migrate my test platform from XP to WIN 7, but the PC-DIO-96 I can't see on the NI-MAX application.
I tried with NI-DAQmx 9.7.5, 9.8, 9.9 and NI-DAQ traditional 7.5, but I can't see the device PC-DIO-96 on WIN 7.
Someone that provide me any information??
(4,512 Views)
Hello victor_valdivia
This DAQ card is supported in our Traditional NI-DAQ driver and in the newer driver, NI-DAQmx.
However, Traditional NI-DAQ only supports Windows 7 32-bit, if you are using this version follow the next instructions:
-First open the control panel on your computer, go to programs and features, and in here open the NI software. In the window that is opened, under the products tab, select NI DAQ 7.5 and then click remove.
-After you uninstall this version of traditional DAQ, go to the next link and download the new drivers:
Traditional NI-DAQ (Legacy) 7.5 - Windows 8 32-bit/7 32-bit/Vista 32-bit
-Once you have this drivers installed, go to NI Max and go to Tools>>>Reset Configuration Data. Reboot your computer and see if you can find your device.
Also try installing the drivers on another computer and see if the same behavior is present.
If you are going to use a 64-bit OS version, you will need to use the NI-DAQmx driver. If your original test application was coded with Traditional DAQ, it will need to be re-written using NI-DAQmx function calls. This can be a bit tricky as these drivers have some differences. The following tutorial outlines some key points about transitioning to NI-DAQmx:
Transition from Traditional NI-DAQ to NI-DAQmx in LabVIEW
Please let me know if you have any further questions about this issue.
Brenda
(4,268 Views)
