Digital I/O
PCI-6023 Initialization of Digital port
When PC starts, PCI-6023 starts with the digital port initialized as input. How can i initialize this port as output with value 0x0? The problem is that for the 2 or 3 minutes that my PC takes to load windows and then 1 minute for me to load my vi, the circuit connected to DIO port, reads a boolean value 1, which is not desired. Thank you.
(3,350 Views)
Hello argiris,
The article linked below addresses your question. I believe it will solve your problem.
http://digital.ni.com/public.nsf/websearch/B4FED0C879BD155F862569ED00142DC7?OpenDocument
I hope this helps!
Matthew C
(3,350 Views)
