Digital I/O
PCI 6254 - Can we do DIO Read/ Write using Port 1 & Port 2?
I'm currently using NI-DAQ-6254 board. As i understand, it has 3 ports:
Port 0 (P0.<0..31>)
Port 1 (PFI.<0..15>)
Port 2 (PFI.<0..15>)
I'm able to use the Port 0 for Digital Read and write, but am not able to do the
same with Port 1 & Port 2.
According to he 6254 Spec, Port 1 & 2 can be used for Static Digital I/P and O/P.
Then, why am i not able to read digital data using Port 1/ Port 2??
I was trying to use an external clock as there is no onboard clock engine on this
board.
rkpat
(3,892 Views)
You can use all 3 ports to perform static Digital I/O. If you program involves any type of sample clock, then you are no longer performing static DIO, but correlated DIO.
You should consider opening a static DIO example and configuring it to read/write from all of the ports. This should work fine for you since there is no clock invovled.
Jared A
(3,885 Views)
Hi Jared,
thanks for the reply.
just need another clarification...
Am i right in assuming that we cannot do CORRELATED DIO using port 1 & 2??
also, what is the difference between STATIC DIO & CORRELATED DIO?
i will be using an EXTERNAL CLOCK for digital output and input. in this case,
can i still use Port 1/2?
thanks,
Ravi
(3,880 Views)
Correlated DIO enables digital and analog functions to be synchronized with hardware-timed precision. Basically, a clock is associated with the digital functionality.
Static DIO is basic digital IO that employs no handshaking or hardware-controlled timing. There is no clock associated with the functionality.
You are correct in that Port 0 of your M Series is the only DIO port available for correlated DIO. And unfortunately, the use of an external clock for ports 1 and 2 is not possible with the M Series. Only port 0 can utilize a hardware clock.
I hope this helps.
Jared A
(3,873 Views)
