Digital I/O
PCI-6503 and PCI-DIO-96 handshaking with DAQmx 8 for Linux RHEL WS 3
Has anybody successfully used the DAQmx 8 C handshaking functions on the PCI-6503 or PCI-DIO-96?  When I try the handshaking functions to read data I see the assertion of STB* by my circuit followed by the assertion of IBF by the NI board.  After that sequence, the INTR signal should go HIGH indicating that the assertion of a PCI interrupt.  When the interrupt is serviced and the buffer is read by the CPU the IBF signal should go LOW again.  I never see the INTR signal go HIGH and the IBF go LOW.  Finally, the handshaking function times out.  Any ideas?
Message 1 of 1
(3,613 Views)
