Digital I/O
PCI-6503 maximum acquisition frequency ?
Hy,
I work on a project in order to check the output on an electronic rack. I have only at my disposal Ni PCI-6503... (we can't buy another DIO card... Smiley Sad )
I'want to generate and acquire TTL signals... but what is the maximum frequency ?
Brice Detroussel,
Student at INSA-Toulouse
FRANCE
(3,262 Views)
Typically, there is no limitation on the frequency you can generate with your 6503. The frequency is software control, so the limitation will come from Windows, your PC setup, code efficiency etc...
See page A3 of the attached document.
http://www.ni.com/pdf/manuals/374938a.pdf
Regards.
ClémentG
(3,241 Views)
