Digital I/O
PCI 6503 self test error
   I have some PCI-6503 boards and I need to install them in PCs with WinXP to use it with traditional NI-DAQ and SCXI-1000 chassis.
The boards are Ok , but i can understand why, in some PC, when I try to make a self test with traditional DAQ in MAX , I get a "The device did not pass the test" error. (with DAQmx the self test is passed without any errors)
Having a look at the detailed error, it is a -10461 resourceReservedError, but there is no application or nothing else that can reserve the board. Is a brand new XP installation.
Any Idea on how to solve?
thank you so much.
(1,420 Views)
Reassociate Traditional NI-DAQ (Legacy) Device with NI-DAQmx Driver
Try to reset the hardware to release it from DAQmx driver,
https://tmesystems.net/
(1,398 Views)
I have the opposite problem, Able to use it wuth DAQmx but not with Traditional DAQ.
I' ve tried you solution but nothing has change..
(1,359 Views)
