Digital I/O
PCI-6528 connector
Can anybody provide the part number for the matting connectkor to the DI/O connector on the PCI-6528 card. We are not going to use very many channels and the brake out box dose not fit in to the designe.
Thank you
(3,216 Views)
Hi TeBlues,
The 6528 has our 100 pin connector - you can find the part numbers for the connector and cable connector from this KB: Specifications and Manufacturers for Board Mating Connectors
The part number you are probably looking for is the cable connector - AMP 749621-9.
Hope this helps,
Andrew S.
(3,205 Views)
