Digital I/O
PCI 6533 + stepper motor + incremental rotary encoder
Hi everyone,
I can successfully control stepper motor with my DIO card.  But few days ago I get an encoder and tried to connect it with my stepper motor and PCI 6533 as shown in figure below. Then I used MAX`s Test Panels to verify signal`s changes. Outputs worked perfectly but according to inputs...there was no reaction. As I checked it with LPT, everythig seemed to work OK. I used the same optocouples for inputs as for outputs. Is anybody able to tell me where I made mistake ?? Smiley Sad
Anything you could tell me would be very helpful.
Thank you
(4,031 Views)
  • Add a resistor (eg 10k) between the output of the LM7805 (+5V) and the outputs of the optocouplers :
  • +5V  -10k-  P0.0
  • +5V  -10k-  P0.1
  • +5V  -10k-  P0.2
  • Ensure that the outputs of the encoder are able to provide enough current (about Uout - 1.2 / 470) to drive the optocouplers.
And alternative to the 12V power supply + LM7805 voltage regulator would be to use the +5V on pin 1 of the DIO card.
(4,007 Views)
I forgot to connect +5V with D PULL Smiley Mad Now everything seems to work OK.
The thread is closed I think 😉
(4,005 Views)
