Digital I/O
PCI 6534 Onboard Looping Input/Output: how to control output loop iterations?
I loop a pattern from onboard memory with a specific clockrate while clocking in data with the same clock (like in the Onboard Looping Example.Vi) I can control the number of scans to read within the while loop - but how can I control the number of iterations of the onboard loop? I need to loop a pattern x times while clocking in a pattern of the same size x times. The output loop is much faster than the input loop, so for one input loop it has done mutiple iterations.
Any ideas?
TIA, Andi
Message 1 of 1
(3,235 Views)
