Digital I/O
PCI-DIO-32HS (PCI-6533) setup problem
ok, i've found exactly where the problem is occuring. i'm going to try and get permission to post the main VI asap, but until then, i can describe the chain of VIs that results in the error:
within a while loop (with a bunch of other stuff):
shift register v -> trigger config -> DIO write -> DIO start -> DIO wait -> buffer control -> shift register ^
(where 'v' and '^' are my attempts to draw up and down arrows with text)
the first time through the loop there is also a DIO clear and DIO config before the trigger config. the error is generated inside the buffer control VI at the end of the chain.
here's the basic input information for the VIs, not counting basics like taskID
DIO config: port list={0; 0:3}, direction=output, #scans=100000
trigger config: trigger type=start trigger, mode=on
DIO write: write location={0; from start of buffer}, digital data in (program specific, i suppose)
DIO start: #scans=100000, handshake source=internal, clk freq=100000.00
DIO wait: direction=output
buffer control: control code=reserved
i know this is about the *least* convenient way for me to present this information, however, my labview programming skills are nil. i'm attempting to recreate this in an independent VI, but let's assume that i won't be successful in any reasonable amount of time 🙂
thanks again for all your help!
Message 11 of 15
(1,632 Views)
If you are concerned about posting your VI, you can always email it to support@ni.com, attention Sean C. I will probably need to see your VI to be able to help you out.
If not, let me know when you have this error reproduced in an independent VI.
Sincerely,
Sean C.
Message 12 of 15
(1,632 Views)
apparently i can't email directly to support@ni.com.
i'm in the process of getting some stuff sorted out with getting my email address associated with our support package, so i guess i'll email it when that's all worked out...
Message 13 of 15
(1,622 Views)
I apologize... Please go to http://sine.ni.com/apps/we/niae_asc.main to email your VI.
Sean C.
Message 14 of 15
(1,619 Views)
Did you ever resolve this problem?  We upgraded to a faster computer system and also started having underflow problems with this card.
Message 15 of 15
(1,070 Views)
