Digital I/O
PCI-DIO-32HS Win10 Replacement
I'm currently looking to design an upgraded system that will run on Win10 using a similar card to the PCI-DIO-32HS as this is the card that was used on the original system back on WinNT. Is there a direct replacement that is currently being manufactured and can run on Win10?
Thanks.
(1,356 Views)
There are quite a few PCIe-based candidates, not just one specific replacement.  The best choice will depend on a lot of considerations.  I'd recommend you call in to get recommendations from NI's technical sales group.  They'll be best equipped to help you narrow down your options.  You can always come back here if you want 2nd opinions after all the relevant requirements and trade-offs are understood.
-Kevin P
(1,331 Views)
