Digital I/O
PCI-MIO-16E-4. Timing digital I/O lines
Could I simultaneously generate five squared waveforms of diferent frequencies but with a common multiple of them with digital I/O lines.
Frequencies could be for example:
100Hz, 120Hz, 160Hz, 60Hz, 40Hz.
The common multiple would be 2400 Hz
¿Could I sincronize the five digital outputs with a 2400 Hz internal clock and with five differents buffer of at least 60 samples (40Hzx60=2400Hz) to generate these five frequencies?
(3,444 Views)
Juan:
The PCI-MIO-16E-4 device does not support hardware timed digital operations. You will need the PCI-DIO-32HS or other 653x digital devices in order to do that.
June
(3,444 Views)
Hello;
The board you are using the doesn't supported strobed operations, meaning that the digital lines will be updated through Software calls.
To accomplish that task you need a digital DAQ board, such as the PCI-6534.
Hope this helps.
Filipe A.
(3,444 Views)
