Digital I/O
PCIE-6251 and Digital out (from PCB)
I'm new on this forum that has why I will say hello first.
I have card PCIe-6251 and I wanted use it digital out to control steping motor. I make program in LabView: http://rapidshare.com/files/229609147/jedna_linia_2.vi
Card PCIe-6251 is connect to board
On board write that it is patent N.I.
Unfortunately, I don't know how I make use this board because I don't know on whitch pin on board will be signal when I start program. In program I choose exampel dev1/port0/line2.
I checked all ports and pins on board but I didin't find signal(i use oscilloscope). Now I don't know were is problem. Mayby my program is not good??
I ask for a halp. For all information I thanks.
I'm stunent:)
(3,648 Views)
I didnt understand what kind of  board you exactly use for connecting the signals.
You can use "Test panels" inside of MAX to generate signals on desired digital outputs so you will not have doubts about your program working correctly. To be able to use "Test panels" you have to select your card inside "Devices and Interfaces" - "NI-DAQmx devices".
You also can perform "Self test" to check do you have any problems with your card.
Franjo Tonkovic
Applications Engineering
www.ni.com/support
(3,607 Views)
