I am using the PCI-DIO-32HS, and in the 653x user manual it states that this card should power up with all lines in high impedance (HiZ). However, this is not 100% true as PCLK2 outputs 5V when my PC boots up (all other lines seem to be fine). Is this due to the card being damaged, or have I inadvertently changed the power-up setting of my device? If so, how can I change it back.
I base my reasoning on a previous post which seemed to suggest this possibilty, i.e. changing the power-up state of a device. Is this at all possible?
Thanks for the help
