Digital I/O
PFI line for counter and digital boolean input simultaneously
I have a question concerning the digital I/O and the counter.
I use a 6210 card for detecting a TTL signal. Physically I wire the TTL output of the device to the PFI0 port for the front counter (ctr0). Meanwhile, I use the same port (line0) for a digital boolean acquisition task.
The problem: the counter worked well, but the the boolean indicator sometimes missed the pulses.
Thanks in advance for your help!
 KXZ
(5,466 Views)
Hi KXZ,
I made the test in MAX and everything was ok.
What do you mean by " boolean indicator sometimes missed the pulses"?
Best regards.
Sabri JATLAOUI - Certified LabVIEW Architect - Certified LabVIEW Developer
(5,381 Views)
