05-03-2010 11:26 AM
05-04-2010 03:02 PM
You will select a counter from the NI 9401 to create the task as in the Gen Dig Pulse example and set the signal parameters from the VI. Once the VI is run, the signal should be output from the designated counter. Can you elaborate on your VI and how the pulse train needs to integrate? Are your questions more about the NI 9401 or the NI sbRIO-9642?
