Digital I/O
PXI-5922 voltage input range
Hi All,
I am using the PXI-5922 to measure a number of sinusoidal waveforms with an amplitude of ~7V over different voltage ranges. One of the voltage ranges is 0V to 10V. In this case my waveform amplitude 1.5V to 8.5V will be outside the +/- 5V input voltage levels of the 5922 specified in the datasheet.
The max voltage span of the 5922 is 10V. Is this limited to +/- 5V or can this be offset to 0V to 10V or is there another workaround that someone could suggest that I could apply in this instance?
Sean
Message 1 of 1
(1,145 Views)
