Digital I/O
PXI-6289 Hardware question
The PXI-6289 module includes two connectors, left and right.
I need only 8 I/O for my circuit design. So, can we use/connect only one connector?
I have heard that we have to connect both in order to function.  I double about it.
Please advise!
(2,283 Views)
It should be fine to use just 1 connector.  I'd recommend connector 0 because the pinouts on connector 0 tend to be compatible with many other NI multifunction devices.  It'll have the signals that almost *all* multifunction devices support.  Connector 1 is where the device-specific signals are found.
-Kevin P
(2,247 Views)
Thank you!
Mike.P
(2,237 Views)
