Digital I/O
PXI 6509 and SCB 100 Port 0 and Port 3 have lines that are high
I am working with a PXI 6509 connected to a SCB 100.  When I run test pannels lines 0,1,2 are high on port 0.  Lines 0,1,2,3 are high on port 3.
I have a voltage of 3 volts measured between Port0 line 0 and Gnd (pin 47 and pin 50).  Nothing is connected to my SCB 100.
I have set the switches to the recomended positions for Digital passthrough.
Sw1,SW2,SW3 => on
SW4, SW5 =>off
SW6 => on
Please advise
Dan Shangraw, P.E.
(4,001 Views)
Update:
I am getting ~ 3 volts on Pins 48,47,46,45
~2V on pins 44
Is my hardware toast?  There is 5V on pin 49 am I getting some crosstalk?
Dan Shangraw, P.E.
(4,000 Views)
Accepted by topic author ASTDan
I found the problem!
It was a bent pin.  Straightend it out and now it works!
Dan Shangraw, P.E.
(3,988 Views)
