Digital I/O
PXI 6511, 6512 and 6513 Digital I/O Modules: NI-MAX Problems
Hello Everyone,
I have PXI 6511, 6512 and 6513 digital I/O modules. The datasheet information is the figure above. I want to test these modules before start my project. I used NI MAX for the test. I can see my modules where their own slots in Devices and Interfaces (like this).
For example about PXI-6511, the connection in the figure below is established using pins 1 (+) and 9 (-) by applying a constant 12 V or 24V voltage. In test panels, i want to see a LED always ON (HIGH). I used port0/line0 for the test. But there is no any change.
And then, i tried another test way that creating NI-DAQmx Task for PXI-6511 digital input module (like this). I set acquisition mode that 1 Sample (On Demand) according to this. I tried to run. But there is no any change.
As a last way, I used LabVIEW for the test. Block diagram has Create Channel, Start, Read, Clear and Simple Error Handler
Creat Channel (Digital Input)  --> lines terminal --> port0/line
Read (Digital Bool 1Line 1Point) --> data terminal --> test LED ...
I applied constant voltage. But there is no any change.
What could be the problem? Thanks in advance for your answers.
Best regards.
LabVIEW version: 2023 Q1
NI-DAQmx version: 2023 Q1
(2,365 Views)
From the simplified circuit diagram of 6511, it looks like inverted logic i.e., no signal = high (pull up to 3.3V) and signal = low (pulled down by the opto isolator) unless the rest of the logic takes care of inversion.
Santhosh
Soliton Technologies
(2,325 Views)
I'm sure I've set up the connections correctly. What do you think why can't i see the changes on NI-MAX. I have tried for three modules.
(2,237 Views)
Hey,
did you find a solution for your Problem? I have a similar problem, im trying to test my digital I/O PXI-6514 with NI MAX to see if the outputs are working, but so far it doesnt work....
I have measured with a multimeter but there is no voltage....
Does anyone have a solution for this?
Regards
Lucas
(525 Views)
@LucasHapple wrote:
Hey,
Regards
Lucas
Please describe your exact test circuit.
Santhosh
(518 Views)
Thanks for your answer. I just found out that the PXI6514 needs a power supply connected. I thought it is a typical output which provides the power... my bad..
(484 Views)
