Digital I/O
PXI-6534, Load onboard memory and enable looping
I would like to program the PXI-6534 from a Linux application. I can talk to the card and set the registers. However, the Hardware DDK only contains information on the PXI-6533 (not the 6534), and there are two differences.
The PXI-6534 has onboard memory, and a onboard looping mode that I need to use. The register map for the 6533 (from the DDK) does not include any information about these features (because they don't exist on the 6533).
I found information on how to do it from a windows platform using NI-DAQ, but I need to do it from Linux. I have a driver, but need information on what registers to talk to and their formats.
1. How do I load the PXI-6534 onboard memory and enable it (what registers and f
ormats do I use)?
2. How do I enable the PXI-6534 onboard memory looping mode (what registers and formats do I use)?
Thanks in advance !
(3,656 Views)
Please contact your local field sales representative to discuss your application and possible Linux solutions using the 6534 card. Programming the 6534 card is considerably more complex than the 6533 and NI currently does not have register level programming information available for this card.
Click here to find you local field sales person.
Christian L
NI Consulting Services
authored by
Christian L, CLA
Systems Engineering Manager - Automotive and Transportation
NI - Austin, TX
(3,656 Views)
Sigh ... that's what I did, and he suggested I try the forums 😞
(3,656 Views)
Doug,
I assume you've been working with Jared McInelly. I'm talking with him to find a solution for your request.
Christian L
authored by
Christian L, CLA
NI - Austin, TX
(3,656 Views)
