Digital I/O
PXI-6551 temperature and time dependence of channel skew
Hi All,
What is the temperature dependence of the room-temperature-calibrated channel skew for the HSDIO PXI-6551?  Suppose Dynamic Technology measures (after calibration or 'as left') the channel skew to be 60 ps for channel 3 at 23.2 degC.  How does this value change with temperature?
There is also probably a known temporal drift.  How much will this vary over a two year period?
Please advise.  I'm looking into the possiblity of using the calibrated channel skew values to obtain higher accuracy.
Thanks!
Anand
(4,059 Views)
Hi Anad,
I don't see any of this in our datasheets, I will need to look into this. Typically we have a range for how temperature affects a measurement, something like +/- X ppm/deg C.
--Michelle
(4,039 Views)
Accepted by topic author ajog
It looks like Ryan M addressed this in another one of your posts:
using calibration data for PXI-6551 as compensation to obtain higher accuracy
--Michelle
(3,995 Views)
