Digital I/O
PXI 6552: Generate Clock, Strobe, Trigger, Data Signals
Hallo,
I'm new with Labview and NI-PXI, so sorry in advance if my question looks stupid.
In my Chassis there is (other than a PXI-8336) a PXI-6552. With these devices I have to generate and send (each on a different line) a signal timing (the protocol is fixed) composed by:
- clock signal (200 ns);
- a strobe signal;
- data signal;
- trigger signal.
Data is made up of 10 bits and the object that receives these signals waits for two triggers that can be sent in 2 different moments (I'd like to add 2 bottons, one for each trigger event).
I found severals examples that could have helped me but, for my fault, I'm still confused. Can you give me any suggestions?
Thanks a lot!
Ilaria
Message 1 of 1
(4,518 Views)
