Digital I/O
PXI 6555 Singal Routing
Hi
I want to generate a singal via PXI 6555, and make this singal as the external trigger source of another card in a same PXI chassis. So I want to route this singal through PXI trigger line. I can route singal from PFI0 to PXITrig0 using function "niHSDIO_ExportSignal", but my generated singal is on channel DIO0, how can I do the route? Thanks.
(3,646 Views)
Hi Bai,
After refering to the spec of 6555, I think you can use DIO <0..23>, PFI 1, PFI 2, PFI 4, and PFI 5 for generation.
As described in the document below, DIO cannot be routed internally to pxi_trigger line.
Destinations → Front Panel Backplane Internal
Sources
CLK
OUT
PFI 0 PFI <1..3>,
PFI <24..31>
DDC CLK OUT/PFI 4 PXI_TRIG <0..7> PXI_TRIG <7> PXIe_DSTARC Start
Trigger
(Gen)
Pause
Trigger
(Gen)
Script
Trigger
(Gen)
Stop
Trigger
(Gen)
Start
Trigger
(Acq)
Advance
Trigger
(Acq)
Ref
Trigger
(Acq)
Pause
Trigger (Acq)
Front Panel
CLK IN
PFI 0
PFI <1..5>, PFI <24..31>
So I think you should use PFI 1, PFI 2, PFI 4, and PFI 5 for your purpose and route them to pxi trigger line.
(3,631 Views)
How can I generate singal use PFI1, is there a demo?
(3,627 Views)
