Digital I/O
PXI 7833R initial state
Hi:
  I am using a PXI 7833R digital I/O line to generate digital signals. If I did not send a control to the line , what is the output voltage ? what is the output difference between that I send a 0 to it and that I do not send control to it?
  Thanks.
(4,147 Views)
Hi:
By default the digital output lines of any 783x device will output a high value of 3.3V. This knowledgebase written for the 7831R also applies to the 7833R and addresses your question.
http://digital.ni.com/public.nsf/websearch/D58C269F7771770E86256F490082E6C8?OpenDocument
Jaideep
(4,133 Views)
Hi
          I think you just misunderstood my question.
I was asking if I make the digital I/O float or I did not send a signal to control the line. What is the output in this situation?
       What you said is the default High output is 3.3V.
(4,125 Views)
anybody knows that?
(4,119 Views)
As the manual state on page 2-2, the DIO lines are at high impedance during power on. When nothing is written to the lines they are ouputting a value of 0.
Ame G.
(4,099 Views)
