Digital I/O
PXIe-7822 front panel connector information
I would like to create a custom PCB for interfacing to the PXIe-7822 RIO board.  I would like it to have the same front panel connector as the 7822 so that the SHC68-C68-RDIO2 cable can be used to connect the two boards.
What is the manufacturer and part number for this connector?
Thanks.
(2,560 Views)
Accepted by topic author Sneed123
68-pin VHDCI connector is used on the PXI 7822 RIO board and SHC68-C68-RDIO2 cable. As per the below-cited link, the new replacement part or compatible part is,
Manufacturer: Honda HDRA-EC68DT+
NI Part Number: 785753-01
This information should help you find the equivalent male/female equivalents from the connector manufacturer.
Reference - https://www.ni.com/en-us/support/documentation/supplemental/17/vertical-vhdci-connector-p-n-780389-0...
Cable pinout - https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000004BElSAM&l=en-US
Santhosh
Soliton Technologies
(2,426 Views)
