Digital I/O
Parallel port digital I/O
I want to control a simple valve driver circuit I have with a TTL logic signal from my computer.  I downloaded the basic VI:
Download - Access_Parallel_Port_with_VISA.llb
that allows me to change the voltage on 8 of the pins on the parallel port.  I can change the voltage on a given pin but it toggles between roughly 0 volts and .26 volts.  A couple questions:
Q1: What is considered TTL logic?  Is it 0 to 5 volts with an upper and lower threshold voltage level?
Q2:  If someone has been able to send digital I/O signals with voltages giving a TTL logic "high" or "low", could you tell me how you did it?
Perhaps outputting 0 and .26 volts is normal and people are just somehow boosting the high voltage.  I'm not an electrical engineer so I have to learn this stuff the hard way.
Thanks to anyone who takes the time to reply!
shawn
(3,269 Views)
Please continue discussion for this thread at this link.
Thanks!!
Chris R.
(3,260 Views)
